Can’t get my concrete to stick
Old 10-04-16, 06:35 AM
K
I have a piece of concrete that fell from the underside of my outside balcony which is the entrance to the bachelor apartment. It seems like it was repaired before and now it’s come back down. I tried regular concrete with concrete cement but I still can’t get it to stick. I then tried Versafix, Bomix with a piece of plywood and a 2x4. It stuck but when I hit it, it sounded hollow. With little force it came down.
What can I do to fix this problem?
Here are some pictures. At its deepest it’s two and a half inches.
Old 10-06-16, 06:48 PM
G
Received 2 Votes on 2 Posts
Not pushing it, but I think Gorilla Glue claims to fix problems like yours.
Old 10-11-16, 02:52 PM
Received 1 Vote on 1 Post
we've got 1 of those projects on the board now,,, pressure wash (3,500psi w/turbo nozzle), dampen underside of work, trowel on overhead/vertical patch polymer-modified cement,,, for uniformity of thickness, we scrape w/4' piece of using upside down screed rails,,, did a lot of this work for dot's & that method/materials was always spec'd
locally our apron store's now carrying cement-all - yes, more expensive than quik/sak krete's but you get what you pay for
IF you do the work properly, it won't sound hollow
Old 10-11-16, 04:40 PM
looks like your stuff's possibly good for vertical but ovhd's a bit more difficult,,, try a pro const supply house,,, keep it stiff as too much wtr destroys the adhesion, cohesion, & strength
