Small concrete fill
Old 10-12-16, 12:18 PM
B
Received 5 Upvotes on 2 Posts
Small concrete fill
I've helped do some concrete work before but it's been years since I've done any.
I have this small patch of dirt in the front of our house that I want to fill.
I want to have the surface have an angle down, away from the foundation so water won't pool near the house and will drain way.
How deep should I make the area to be filled. Is gravel a good idea as the substrate? My friend has a hand compactor tool I can borrow.
Can I make a cross section Control Joint? Just one horizontal and vertical line?
The area is about maybe 4'W X 5'L
The first picture is the area I'm talking about, but in the second picture, the surrounding pathway has also cracked and caved in a bit. I also want to remove and repair those. Should I have a seem that divides the two sections?
**Note - I'll be removing those rocks that line the edge of the area.
Old 10-12-16, 06:10 PM
Received 125 Upvotes on 110 Posts
Got a real mess there.
That walkway was done wrong, most likely it was not properly prepped that's why it's cracking and sagging.
Seeing all the miss matched concrete tells be this has been an ongoing issue.
Add that concrete against's the stucco and it going to start to fail.
Wish we could see the big picture of the whole lay out.
Adding gutters with drains ran under ground to daylight may help.
Old 10-12-16, 06:25 PM
B
All that concrete is very old and probably done by my grandfather, or a friend that didn't prep it well.
If I break out those 4 square sections near the house, level the soil, add some gravel, compact and repour - should it be alright?
What about the section I want to fill in? - in the first picture.
Old 10-13-16, 05:54 AM
W
Received 60 Upvotes on 52 Posts
Repairs
I would do the walkway repair first. This will give reference for the proper slope and elevation of the fill-in area.
Old 10-13-16, 10:01 AM
B
What is the best way to break up and remove the old concrete?
Old 10-13-16, 01:27 PM
Received 740 Upvotes on 646 Posts
You'll need to either rent a jack hammer or use a sledge hammer .... don't forget the bengay
Old 10-13-16, 08:40 PM
B
Does it seem like something I'd need a permit for?
Old 10-14-16, 05:31 AM
Depends on on your locale, some give a lot of leeway while others want a permit for most everything
I once lived where they required a permit to put in a vegetable garden
The only way to know for sure is to call the permit office.
