Retaining Wall Drainage
Old 01-30-17, 04:50 AM
P
Will installing a French drain behind a retaining wall provide a benefit?
Thanks
Old 01-30-17, 05:49 AM
C
Received 2 Votes on 2 Posts
It is recommended to install drainage and crushed stone backfill behind a retaining wall. You line the area with geotextile fabric [edit] lay in drainage pipe, and fill with crushed stone to 6-12 inches below surface, then wrap the fabric over and finish with soil.
The drainage prevents water from draining through the wall, taking soil with it. It's especially important in freezing climates so that damp soil behind the wall doesn't frost heave and push the wall forward.
Old 01-30-17, 06:06 AM
Received 408 Votes on 364 Posts
.... and you want that drain tile to have an exit for the water it collects.
Old 01-30-17, 08:45 AM
Marq1's Avatar
Received 505 Votes on 468 Posts
A lot depends on what you are building.
I currently have several bolder walls, from 18" up to 4' tall and did not install any drain or use any fabric without any concerns.
In an prior house I had a ravine setting and had multiple 4' high walls stacked up close to 20'. In those I installed inter connecting drain tile from top to bottom.
I'd also be more inclined to put a drain tile behind a paver stone type wall where the wall is a little more straight, if my bolder walls move a bit you would not even notice.
