Thompson's WaterSeal Clear Multi-Surface Waterproofer?
Old 01-30-17, 09:20 AM
How often do I use Thompson's WaterSeal Clear Multi-Surface Waterproofer on the patio cement to seal it?
Old 01-30-17, 09:22 AM
Received 319 Votes on 283 Posts
A lot depends on the weather it sees. TWS can wear away in as little as 3-6 months or last for a little over 1 yr. Basically if it beads water it is still there and working.
Old 01-30-17, 09:59 AM
Can I use the sealer on the patio cement every summer time? Is it ok?
Old 01-30-17, 10:37 AM
Received 94 Votes on 83 Posts
Every summer is probably fine but if it isn't, it's likely because that is not often enough. The knock against Thompson's is it wears away very quickly.
Old 01-30-17, 10:39 AM
Shouldn't be a problem although the better the patio is sealed the slicker it's apt to be when wet.
Old 01-30-17, 10:50 AM
The other issue you may have is whether or not the Thompson's sticks effectively in all areas (especially the low use areas). I have patterned concrete and I've found that using the builders sealer (with sand for grip) is a much better option than using the cheaper Thompsons stuff. You can buy it at local supply stores but it isn't cheap. Here in Canada, a 5 gallon pail runs around $250 but it will last for 3 years+ on patio, 2 years on a driveway.
Old 01-30-17, 04:10 PM
Marq1's Avatar
Received 370 Votes on 345 Posts
Dont, that is the worst krap on the market!
Old 01-30-17, 04:36 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
I was going to say... it would work ok if you applied it once a week. ;-)
BASF makes several good conrete sealers, I would recommend you put your money into something that works... not a cheap substitute.
