Removing mortar from brick surface
Old 03-27-17, 07:13 PM
W
Received 13 Votes on 13 Posts
An unskilled do it yourselfer fixed some loose bricks under a porch slab and got mortar all over the brick surface that is very visable. How can I remove this mortar without damagine the brick surface ?
Old 03-27-17, 09:38 PM
Received 77 Votes on 72 Posts
Got a picture so we can see what your seeing?
Old 03-28-17, 07:05 AM
W
Removing Mortar from Brick Surface
I will take one and post it.
Old 03-28-17, 01:00 PM
W
I tried four times to upload a picture and it failed. Sorry
Old 03-28-17, 01:47 PM
Norm201's Avatar
Received 230 Votes on 205 Posts
What are you doing to upload the pic? You might want to use something like IMGUR. If you need instructions as to how, let us know and we can walk you through it.
Old 03-28-17, 02:26 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Pictures need to be scaled down to web quality. Upload to a laptop and use a free image resizer to scale it down so you can upload. If you camera takes 12 MP pictures, you will never be able to directly upload them.
Old 03-29-17, 03:25 AM
Mortar achieves around 90% of its hardness and bonding power within the first three days of application. After 30 days, mortarís hardness reaches closer to 99%. But don't worry still you can clean it with Muriatic acid. Muriatic acid is a form of hydrochloric acid that dissolves mortar. Be sure to follow the instructions on the container closely. Typically, those instructions say to begin by mixing a 9:1 (10%) solution of water to acid. The acid should always be added to the water and not vice versa.
