How do I repair this brick structure? Don't know what to call it.
Old 04-17-17, 07:03 PM
spirittoo's Avatar
Received 2 Upvotes on 2 Posts
Question How do I repair this brick structure? Don't know what to call it.
The brick structure to the left of the picture that is painted ... there are steps in between it and another one on the other side. The bricks are breaking up in spots and falling out in others. What do I need to do in order to patch it That's the best picture I have right now ... is it enough to see what I can do to repair it? Thanks for reading my post.
Old 04-17-17, 11:41 PM
Marq1's Avatar
Received 1,098 Upvotes on 998 Posts
Its a great picture of the shrub and shovel, a close up of the issue with bricks would be very helpful!
Cant really see what is going on!
Old 04-18-17, 03:23 AM
Received 740 Upvotes on 646 Posts
Are the bricks deteriorating or is it just the mortar? If it is the bricks itself you really only have 2 options; replace or stucco over it. A better pic or two would be helpful
Old 04-18-17, 06:04 AM
Received 125 Upvotes on 110 Posts
That sure looks like the brick is failing, likely water has been getting in behind the wall, it was not waterproofed on the back side and the freeze thaw cycle is breaking it up.
Old 04-18-17, 09:59 AM
spirittoo's Avatar
Arrow Best Picture I Have For Now
Yes the bricks are deteriorating in spots due to the freeze thaw cycle. What is stucco? How does it work?
Old 04-18-17, 11:33 AM
Once you removed any loose brick/mortar you'd trowel stucco/mortar over the remaining brick to make it even [might require doing the voids first] Some folks call it parging but I think that is the same as stucco.
Old 04-18-17, 07:54 PM
spirittoo's Avatar
Arrow I'm not seeing it
I checked home depot and lowes for stucco, but I don't see anything listed. Does it go under another name at those stores?
Old 04-18-17, 11:27 PM
ray2047's Avatar
Stucco:
Stucco is usually a mix of sand, Portland cement, lime and water, but may also consist of a proprietary mix of additives including fibers and synthetic acrylics that add strength and flexibility.
Old 04-19-17, 02:36 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Look in the concrete section of the stores. Rapid Set 25 lb. Stucco Patch-71020025 - The Home Depot
Old 04-19-17, 03:52 AM
.... and I have used mortar for stucco repairs.
Old 04-19-17, 10:24 AM
spirittoo's Avatar
Arrow Not Available At Local Home Depot
Unfortunately that product is not available at the home depot in my city. So I can use mortar as a replacement ... they have the mortar mix at home depot in Ashtabula.
Old 04-19-17, 01:43 PM
ray2047's Avatar
Try real lumber yards and hardware stores.
Old 05-28-17, 11:39 AM
spirittoo's Avatar
Arrow Got Better Pictures
I took some better pictures of the steps so you guys can see what I am dealing with and can give me an idea what must be done to repair it. Thanks.
Old 05-28-17, 12:13 PM
chandler's Avatar
Oh, gee, it's too far gone to be "repaired". I would remove the entire thing and either rebuild it with brick, or wood.
Old 05-28-17, 01:54 PM
I agree!! once you remove what isn't fit to attach the repair too you might not have anything left. It should be quicker/easier to rip it out and start over.
Old 05-30-17, 12:53 PM
spirittoo's Avatar
Arrow Oh oh ... Never done nothing like this before
Oh my ... I didn't anticipate having to replace it. I've never done anything like this before. Say if I replace it with wood. What kind of tools and materials I would need to do this project?
How would I go about doing it? Explain it to me like I was a four year old.
