Problem with ashpalt sealer water.
Old 07-19-17, 09:43 AM
B
Received 1 Upvote on 1 Post
I sealed my driveway, then washed out the bucket s ---2 anyway. Wasn't paying attention to where the waste water rinsed out . It ran down my old asphalt- to An old well pitted concrete curb.Its now stained with a black water film. 10' of curb 4" wide i guess.Have you any tips on removing this dried on "asphalt water?" Anything you THINK might work- please post it.cleaners thinners etc. i just don't know thanks much for stopping by bob s
Old 07-19-17, 10:13 AM
Received 1,190 Upvotes on 1,147 Posts
Do you still have the buckets? I would look to see if they list a solvent on the label.
Old 07-19-17, 10:56 AM
Received 3,424 Upvotes on 3,070 Posts
Most of those sealers are water based. That means water and soap cleanup.
After the product is dried.... soap and water is no longer effective.
I'm thinking pressure washer.
Old 07-19-17, 11:24 AM
Received 742 Upvotes on 648 Posts
Denatured alcohol works on dissolving latex paints but I have no idea if it will work with driveway sealer. It will wear away with time. Pressure washer will probably work.
Old 07-19-17, 12:42 PM
Marq1's Avatar
Received 1,111 Upvotes on 1,010 Posts
I'm thinking time will erase the memories, and stain!
Old 07-19-17, 03:50 PM
B
THANK YOU ALL! for the tips the stuff i put down, has Another ingredient in it, where as- the stuff i had laid down, is strait coal tar-mix-- power washer it is- after it sets abit thanks all bob s
Old 07-29-17, 03:24 PM
B
so now i get battery acid on my concerte garage floor
Guess i'll never win or wise up again man age is a b**** bob s
Old 07-30-17, 03:04 AM
If I remember correctly a muratic acid solution will clean up battery acid stains.
Old 07-31-17, 04:16 AM
B
NOPE! tried it nothing thanks bob s
