paint for concrete front steps
Old 11-10-17, 11:22 AM
H
I want to retouch the exterior concrete front entrance steps, which are structurally sound but look a bit worn out (as in the image), by leveling the surface, priming and painting. What would be a good product for filling shallow (1/2" or so) deeps and worn out patches on horizontal concrete surfaces? Also any suggestions for the primer and the paint? Would appreciate any suggestion! Best wishes, h.
Old 11-10-17, 12:09 PM
Received 786 Upvotes on 689 Posts
IMO a concrete stain is better to use than paint. It doesn't require a primer and while it will wear away over time - it won't peel. I'd avoid patching the concrete, thin layers are prone to come loose.
Old 11-10-17, 03:37 PM
D
Concrete needs to breathe. I don't recommend any sealer, paint or stain.
Old 11-10-17, 05:33 PM
H
Appreciate the responses! I hope there is a way to make the old concrete steps look better. Would all those self-leveling concretes and concrete epoxy coatings not work for some reason on exterior steps? I have heard of concrete resurfacing and wanted to know if this is something I could use here.
Old 11-11-17, 04:38 AM
D
I would clean them with a gas powered pressure washer first. That may be all that's needed.
Old 11-11-17, 08:28 PM
H
Well, apparently not. The stupid owner (me) still wants to have it resurfaced.
Found on TOH:
In the past, when a concrete patio or driveway started to show serious signs of aging, using a jackhammer or bringing in a bulldozer were the only repair options. Today there are more practical alternatives.
They say that some polymer fortified concrete mixes might be right for the job.
Old 11-11-17, 08:58 PM
Are you feeling ambitious? Do a web search for DuRock's Jewelstone product/process. I've really wanted to try it, but have been too busy with other projects.
BTW. That's a beautiful door.
Old 11-12-17, 03:59 AM
D
I compare the art of resurfacing the stoop to that of a drywall skim coat. If you want to take a shot at it, Ace has a topping mix. I would use a bonding agent. It's getting cold here. What's the temp there?
Old 11-12-17, 08:22 PM
H
Thanks for all the info! Donato_, It's 60-65°F during the day and around 50°F at nights for the next week or two. Yes, topping mix is something I was thinking about, should be a straightforward project. SturdyNail, DuRock's Jewelstone coat sounds tempting: resurfacing and custom colored texture at the same time. Can one see/buy DuRock's Jewelstone in the US?
I can only claim credit for the sidelight; it's stained red oak. The door was from a clearance sale in HD.
Old 11-13-17, 05:04 AM
D
It's warm enough to do the job.
