burying wire in shallow concrete channel
Old 02-16-18, 03:38 PM
Hey folks, I've got an internet wire that needed to jump over a sidewalk. There's a nice big crack I was able to jam the wire into, but I'd like to seal it in there. You got any ideas on how to best do that?
I hammered a few small pebbles into spots to help keep it in a little. Eventually muck will get in there and just keep it down - I think. But for the interim, what product should I use? I've got:
Floor Tile Mortar: Thin-set, floors, interior, use over concrete, masonry, mortar beds
All-Purpose Stucco Patch: repairing stucco surfaces, durable and permanent
Rapid Set Mortar: interior/exterior, hardens underwater, low-shrink (25lbs)
two tubes of DAP 3.0 Concrete & Masonry, waterproof, paintable in 1 hr
Old 02-16-18, 09:03 PM
Received 4,103 Upvotes on 3,685 Posts
That is an expansion joint. You don't want something completely hard filling it in,.
The DAP 3.0 should take care of it.
Old 02-17-18, 02:49 AM
Received 870 Upvotes on 761 Posts
Caulk was my thought also. Make sure the concrete is clean and dry first.
Old 02-24-18, 05:09 AM
Received 1 Upvote on 1 Post
doesn't look to be an exp jnt but difficult recognize as its a tooled jnt,,, i'd 'chase' the jnt w/diamond blade on 4" grinder to create slot for wire, place wire, clean sidewalls, & seal w/either 100% silicone or np1 or np2 - either ns or sl grade
Old 02-24-18, 05:16 AM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Yeah NP1... or if you can't find that maybe Sikaflex or Loctite S10. Keep it inside the crack, don't overfill it... you can tool it flat with a little paint thinner on your finger if needed.
