04-10-18, 05:29 AM
Gap in corner of lowest level of cinder block- pic included
PIC ATTACHED!
Hello All,
I am working on refinishing my basement and during removal of old framing I noticed WET - FINE MUD / SLUDGE in the floating slab gap. Upon closer inspection I noticed in a corner where 2 blocks come together there is a quarter inch gap which runs about 3 inches HIGHER than the slab floor and as far down as I can see. I can only guess that's the source of the fine deposit and water collecting in the channel....?!? While there is no down spout outside directly above that area of the house that drains in that area, the ground MAY be a bit lower forcing the water towards the house.
Is that un-mortared space in the blocks by design?
To me is seems like there are a few problems that need to be addressed to solve the problem.
Do I want to seal the gap in the blocks??? How?
Getting water routed away from the house in that area?
Removing the sludge from the channel to allow for better drainage?
It would be much appreciated if anyone could answer any / all of those questions!
BIG Thanks Jeff
If anyone happens to have
Hello All,
BIG Thanks Jeff
NC
04-10-18, 10:06 AM
I would NOT seal the slot. It looks like an intentional drainage system. Possibly water collected in the channel is supposed to drain out the slot.
