stubborn moss on cracking driveway
Old 05-25-18, 07:48 PM
G
More moss are growing on my driveway every year, and they are getting more and more difficult to wash off even with a pressure washer. It seems like small cracks are opening up that allows the moss to wedge themselves into. Now I just use brute force and spend more time with the pressure washer to remove them. But this also cause the driveway to chip more.
I think the small cracks may be getting larger when water gets in and freeze. But these cracks are too small to repair with concrete filler. I attached some photos. The moss in the photo survived the first round of pressure washing. You cannot see the cracks but obviously they must be there for the moss to grow out of.
What is the solution to this problem?
The house is in WA state. In the winter there is very little sun and rains alot, and gets below freezing temperature.
Old 05-26-18, 02:08 AM
Marq1's Avatar
Received 535 Votes on 495 Posts
So what is the construction of the driveway, with all that exposed aggregate?
I would think a treatment of herbicide would take care of the plant material and some type of sealer, similar to what is used on asphalt drives would seal!
Old 05-26-18, 02:55 AM
Received 427 Votes on 382 Posts
That rough surface lends itself to collecting dirt and allowing moss to grow. You might need to wash the driveway more often.
Old 05-26-18, 05:08 PM
W
Get a garden sprayer and some 'wet and forget' and apply once every season
Old 05-26-18, 05:42 PM
XSleeper's Avatar
Received 990 Votes on 901 Posts
Water, salt, vinegar and soap usually do the trick. Moss doesn't like salt.
Old 05-27-18, 12:09 AM
Marq1's Avatar
Didn't think about it earlier, I picked up a surface cleaner this spring for my sidewalks and paver patio.
Amazing results, fast and easy, it is exactly what you need to get that surface clean.
https://www.doityourself.com/forum/a...1&d=1527404936
Old 05-27-18, 12:22 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
It's WA. Moss grows on old people walking to the store. Moss grows on dogs who lie down to take a short nap. Moss grows on parked cars fer pete's sake!
