Filling in missing mortar ?
Old 07-18-18, 05:44 PM
W
Received 1 Upvote on 1 Post
Have some mortar missing around the home.
At what depth should I fill spots and what's the beat technique or prep
Old 07-19-18, 04:58 AM
P
Received 1,776 Upvotes on 1,588 Posts
You will have to tell us more. That all depends on the condition of the existing mortar, what you are patching and what you need to do to match the current finish.
If you want you can post pictures. Here are instructions.
Old 07-19-18, 07:19 PM
W
Heres some pics
Old 07-20-18, 03:58 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
That looks excessive. Are any of the bricks loose? I'm not familiar enough with brick work to make a recommendation. If it were me I think I would get a quote or opinion of a professional brick layer.
Old 07-20-18, 05:18 AM
P
The pictures are tiny but in one photo it almost looks like a zig zag pattern which usually happens with a foundation settling.
For repair I would get a bag of type N mortar mix. The kind that contains sand so all you have to do is add water. Clean out the joints to remove any loose mortar and then blow out any dust. With a hose or brush dipped in water then wet inside the crevise to moisten the existing brick and mortar. Then pack mortar into the joint. Depending on the consistency of your mortar you can strike down the joint soon after filling but if your mortar is too wet you can come back in half an hour after it's firmed a bit.
Old 07-20-18, 06:34 AM
W
I assume it's best to fill it . If I leave it I assume water will penetrate ?
Old 07-20-18, 09:08 AM
P
Yes, if there is an opening water will find a way in.
Old 07-21-18, 06:28 AM
W
How about those mortor in a tube ?
