Hole in foundation. Water problems.
Old 08-02-18, 09:26 AM
I have a golfball sized hold on the outside of my house in the foundation, at ground level. The foundation is concrete block covered with parging. I had some snow melting water issues in my basement this winter, and it was probably from water coming through this hole.
I want to patch it with concrete, but should I make sure there is no water in the void first? I can’t see down the hole. And even if there is water, what can I do about it?
any help, suggestions, pointers would be greatly appreciated before I just plug the hole with concrete.
I’d like to make sure I’m not doing something I’m goibg to regret.
Old 08-02-18, 11:21 AM
Received 1,188 Upvotes on 1,146 Posts
Plug it with hydraulic cement and move on. Water can move through concrete so it should dry slowly even if there is water in the cavity,
Old 08-02-18, 01:42 PM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
You might want to take a paint stick... cut it about 3" long... put a screw or small nail in the middle of it (to use as a handle)... then put a dollop of caulk on both ends, insert it into the hole and pull it up against the back of the block tight. Once that has cured, pull the nail or screw out, and patch with cement. This just ensures there is some backing in the hole so that you can pack it full/tight a little better.
Old 08-02-18, 04:50 PM
Thanks for the tips guys.
Old 08-04-18, 02:54 PM
Received 1 Upvote on 1 Post
'cept use sealant (np1),,, caulk'll fail much faster'n the np1
