dish network dish removal from block wall.
Old 11-22-18, 01:06 PM
i have an old dish network dish i need to remove? what are these fasteners and whats the best way (tool) to remove them? photo below.
THanks!
Old 11-22-18, 02:28 PM
It's called a drive pin anchor. The hole is drilled, the fastener is installed into the hole and then the center pin is hit in with a hammer. The easiest way to remove is to use a cold chisel and snap the head of the fastener off.
Old 11-23-18, 03:15 AM
..... and the easiest way to fix the hole is to use a dab of caulking covered with paint to match the stucco color.
