What caused this hole?
Old 01-08-19, 01:27 PM
E
My house has a cinderblock wall along the rear of the property and I noticed this hole along the bottom. About 4 inches or so and has sand inside. Itís the only hole
I checked all my sprinklers and I donít see any water leaks. Any idea what caused it and the remedy? Thanks!
[IMG][/IMG]
Old 01-08-19, 02:06 PM
Received 870 Upvotes on 761 Posts
That looks like rebar sticking up out of the footer/slab. How close is it to the outside of the block? I'm thinking maybe they had to cut the block and then patched the hole ..... and now the patch has failed.
Old 01-08-19, 03:27 PM
E
The ribar is right against the inside wall of the cinderblock. I haven’t been here long so I don’t know if it was a previous repair.
Can I just patch it and repaint? How do you suggest I do it so it won’t come back?
Old 01-08-19, 03:39 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
That was patched at one time, you can see it in the face of the block.
Should try and pull it out, vac out all the loose sand and patch!
Old 01-08-19, 03:41 PM
Received 4,105 Upvotes on 3,687 Posts
Vacuum it out and patch it with hydraulic cement.
Old 01-08-19, 03:51 PM
E
Great! I’m glad to hear it wasn’t an indication of something serious. Thanks for your help.
Old 01-09-19, 05:13 AM
B
Received 314 Upvotes on 277 Posts
What is the purpose of the wall? Hope it isn't the house foundation as there is no mortar in the block joint in the pic(could be others). My guess is the rebar was supposed to pin the block to the footing to prevent relative movement.
Old 01-09-19, 05:48 AM
I think there is mortar there, it's just cracked due to settlement.
Old 01-09-19, 07:20 AM
E
The wall is not part of the house. It’s a wall that separates my property from my back neighbor.
