Drill bit?
Old 06-23-19, 10:11 AM
brian44220's Avatar
Question Drill bit?
So recently bought a Tapcon hammer drill bit with carbide tip for concrete, the guy and homedepot said it would work for what I’m doing, I’m trying to install a latch on the corner of my house between the garage an house but it’s rock not concrete, brick or block, I got about 1/2 inch in each hole before the bit was smoked, not exactly the best hammer drill that I'm using either, what exactly am I doing wrong or what type of bit do I need to use? Thanks
Old 06-23-19, 10:17 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
They are just like using a regular bit trying to drill steel, it's an extremely hard material and those are not the best bits.
I have dozens of them, sometimes it takes a couple but they sharpen easy!
Old 06-23-19, 10:22 AM
brian44220's Avatar
Guess I will go buy some more and get a sharpener to then.
Old 06-23-19, 10:40 AM
Tolyn Ironhand's Avatar
Received 778 Upvotes on 658 Posts
Bits used for concrete, masonry, brick, and block need to be carbide tipped or they will dull instantly. They also cannot be sharpened.
A drill with a hammer function (hammer drill) will work better for drilling into rock when using carbide tipped bits. I am a fan of SDS hammer drills but a "screamer" hammer drill with a standard chuck will also work.
Norm201 voted this post useful.
Old 06-23-19, 11:54 AM
Received 3,593 Upvotes on 3,222 Posts
You cannot use tapcons in rock. It's too hard for them.
You also need to use a diamond bit when drilling rock.
You may need to use lead shields in the rock to screw into.
Old 06-23-19, 01:47 PM
brian44220's Avatar
Any specific brand that you use or know the name of?
Old 06-23-19, 02:13 PM
Lead shields come in all sizes. You may want to use 1/4" - 5/16" - 3/8" galv. lag bolts.
The link below is for 3/8"s but they have all the sizes.
3/8" lead shields
Old 06-24-19, 12:01 AM
Marq1's Avatar
Sure they can, touch them up on the grinder until the carbide is gone, they last for years!
Old 06-24-19, 03:26 AM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
FWIW...use water as a coolant as you drill. I've drilled a few holes on rock with a hammer drill using carbide tipped drills. Lot depends on he kind of rock!
Old 06-24-19, 03:33 PM
brian44220's Avatar
Those are a little think, if I am looking at the correct bits they are around 40 bucks a piece. The lead sleeves are cheep at least.
