Best way to get rid of this excess cement
Old 08-04-19, 09:14 PM
L
I was trying to chip away at excess cement in between the patio and grass of my new house. It's a lot of work, and I didn't get far.
What's the best way to trim off this excess cement? I can't edge my lawn, the edger hits this excess cement easily. Could I used a reciprocating saw to cut through it? Or would a grinder with a cut off wheel work better?
Thanks in advance for your help!
Old 08-04-19, 10:15 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
As you mentioned it's just excess cement, I'd get a 3" wide chisel and give it a tap, should break right off!
Old 08-05-19, 02:17 AM
Received 875 Upvotes on 766 Posts
Would a masonry blade in a skilsaw go deep enough to work?
Old 08-05-19, 03:38 AM
Norm201's Avatar
Received 729 Upvotes on 644 Posts
I think you would put scratch marks on the surface if you used a skill saw. The chisel idea as Marksr suggested is best.
Old 08-05-19, 04:25 AM
Actually it was Marq that suggested the chisel
Whether or not a masonry blade would work would depend on how much space is between the pavers and the concrete.
Old 08-07-19, 10:03 AM
T
Received 55 Upvotes on 46 Posts
Does anyone make a carbide edger blade? Or can you replace the edger blade with round abrasive blade? I don't know what kind of an arbor an edger has but I bet it's not too different from a saw arbor.
Old 08-11-19, 07:35 PM
D
Received 1 Upvote on 1 Post
Rent a saw
Rent a concrete saw for a half day and cut the edge clean off. Quick and easy.
