Asphalt driveway - crack patching, crack filler and then seal
Old 03-29-20, 07:46 AM
D
Received 1 Upvote on 1 Post
I've attached a few photos of my driveway
there are areas that need both patchwork and also crack filler - i plan to use QPR 50lbs asphalt patch https://www.lowes.com/pd/QPR-50-lb-A...-Patch/3656652
and also black jack speed fill with caulk gun for <1/2" cracks
https://www.lowes.com/pd/BLACK-JACK-...-Patch/3027301
And then either hire someone to seal it or consider DIYing that as well.
What do you all think?
In addition, how long after the patchwork and filler are used should I be sealing?
Thank you !
Old 03-29-20, 07:57 AM
Marq1's Avatar
Received 1,101 Upvotes on 1,001 Posts
No pictures, the cold patch cant be used in shallow areas that dont have well defined walls to hold the material, it will simply squish down and out.
Crack filler is good to go once it has cured.
If you seal, dont skimp on the material, you get what you pay and it takes as much effort to apply the cheap krap as it does the good!
Old 03-29-20, 07:58 AM
D
ugh, how do I remove photos I uploaded from a previous post, so that I can add some of the driveway photos here? It keep stating I've 'exceeded my allowed amount - but I'm only trying to post small megabyte photos. Thanks
Old 03-29-20, 08:03 AM
D
Thanks... trying to get the photos uploaded.
Any particular sealer you suggest? I'm in NJ-northeast.
Old 03-29-20, 09:41 AM
Marq1's Avatar
Skip the good, better, and go for best, it's all in the amount of coal tar sealants and emulsifiers they put in the pail!
