brick and mortar worn away on outside cavity wall next to window
Old 05-16-20, 04:57 AM
R
Question brick and mortar worn away on outside cavity wall next to window
Hi all,
I live in an old 40yo house in West Australia which has cavity walls and single pane sliding windows that have been installed into the cavity. What has happened is the bricks are wearing around the window frame as well as the mortar because of the high winds we have here. That has caused significant gaps in certain areas to the point where you can see through to the inside cavity wall.
See here for pictures as i couldn't upload for some reason: https://drive.google.com/open?id=1qQ...W5-pyfOsbwAm2s
My question, is what can i do in this situation? Do i fill it with foam and then use mortar or should I replace the brick and then use mortar?
Thanks for any help.
Richard
Old 05-16-20, 06:01 AM
XSleeper's Avatar
Received 1,718 Upvotes on 1,542 Posts
Cant open your photo link.
Putting pictures in your post
Old 05-18-20, 07:45 AM
R
Trying to add the picture via my phone
Link to picture
Old 05-18-20, 07:48 AM
XSleeper's Avatar
You aren't following the directions in the link above.
Old 05-18-20, 08:02 AM
R
Trying to XSleeper but it keeps expecting a url. I have edited my previous response with a Dropbox link. Please try again.
Old 05-18-20, 09:09 AM
XSleeper's Avatar
You are clicking the image button instead of the paper clip button.
Tuck point the gap with mortar mix.
