2 Inch Gap Between Conc Slabs. How To Fill?
Old 05-28-20, 12:34 AM
D
At some point in the past (before I bought the house), one slab in my conc driveway shifted about 2 inches away from the other one.
They don't appear to be shifting any more so I think someone fixed whatever caused the shift. I'd like to fill in that gap with something -- but WHAT?
I know I'll need to eventually replace the entire driveway but I'm hoping to delay that for a while -- I'm hoping for maybe 5 years.
Old 05-28-20, 05:53 AM
the_tow_guy's Avatar
Received 57 Votes on 47 Posts
One of the concrete pros should be along for best advice. FWIW I think you could just fill it with some concrete. Get a bag (or 2 depending on how much you need) of Sakrete/Quickrete from a box store and mix some up. Trowel it in and smooth it out. May not last, but worth a try. Fast and cheap.
Old 05-28-20, 06:14 AM
XSleeper's Avatar
Received 714 Votes on 661 Posts
You can use concrete mix, but you will have to excavate it so that it's as deep as the rest of the pad is. Wash and scrub the edges with a brush so they are clean and wet before you pour. And you would likely want to use an edger where it butts up to the existing so that you have a gap to put some self leveling sealant into later.
Old 05-28-20, 07:30 AM
Marq1's Avatar
Received 394 Votes on 368 Posts
You could also fill up the gap with sand and fill with 1/2" urethane sealant.
Gap is pretty wide but it will work for short time!
