Tile over latex a problem?
Old 05-30-20, 03:50 PM
D
Received 1 Vote on 1 Post
Exclamation Tile over latex a problem?
Finally getting around to doing the backsplash in our newly remodeled kitchen. Before I caught them, someone painted over the green board on one wall with latex, one coat. Should I be worried about the paint? Would cleaning with TSP be enough?
Thanks for your time!
Old 05-30-20, 04:00 PM
XSleeper's Avatar
Received 790 Votes on 727 Posts
It could be a problem, depending on the type of thinset you plan to use. It would be a good idea to sand and prime the painted walls if the paint is glossy at all. And Versabond was recommended to me by Czizzi a long time ago, and it's probably the best thinset to use, as it sticks well to most everything. I would NOT suggest you use any premixed thinsets.
Didnt know anyone still used green board.
drumz voted this post useful.
Old 05-31-20, 03:18 AM
Received 361 Votes on 318 Posts
If it's flat paint there shouldn't be any issues, if it's a latex enamel I'd at least scuff sand it with 80 grit. My backsplash is applied over paint as was most of the houses I worked on. I don't know any tile men that use premixed thinset.
