Reglue Rocks In Spa Overflow
Old 06-02-20, 08:20 PM
A few of the rocks that were glue together to make the rock group in the spa overflow separated. What glue or method should I use to reattach?
Old 06-03-20, 04:10 AM
Marq1's Avatar
Received 1,111 Upvotes on 1,010 Posts
You would use a cement/landscape block adhesive, it is water resistant for outdoor use!
Old 06-03-20, 07:14 PM
Thanks. Should I take a dremel to remove the existing adhesive or just layer it over the existing adhesive?
https://www.homedepot.com/p/Loctite-...3231/203266767
Old 06-04-20, 03:25 AM
Marq1's Avatar
If loose remove what you can II find that it chips off pretty easy depending on what matl was used.
Old 06-07-20, 03:18 PM
I got a bit of the gray Loctite landscape adhesive on the stone. Is there a way to remove?
