What the best material to finish a concrete patio?
Old 07-13-20, 08:19 PM
I have a concrete patio that is discolored and has small holes that need to be repaired. I would like to screen in the patio with screening material called "super screen" and make the floor look nice. What is the best option for flooring?
The area is roughly 10' x 18'
I have researched you can do:
  • - carvestone but it is expensive and you have to reseal every 2 years
  • - pavestone but it is too thick
  • - epoxy but not sure how well it holds up to the elements
Are there better options, what would you guys recommend?
Old 07-14-20, 04:39 AM
P
Received 1,766 Upvotes on 1,579 Posts
You could grind and stain the concrete.
Old 07-14-20, 04:42 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
I like PD suggestion. However, it's my understanding that epoxy finishes are OK in mild climate areas.
Old 07-14-20, 08:03 AM
P
Epoxies yellow in the sun so I would research carefully before installing it in a sunroom.
Old 07-14-20, 12:00 PM
I'm in Houston and it would be in sunlight from about 9am to 1pm everyday.
Old 07-15-20, 08:12 PM
