Setting clay bricks on mortar bed
Old 07-14-20, 09:39 PM
Received 2 Upvotes on 2 Posts
I have a small area I need to lay down about 12 chicago bricks on a mortar bed about 1" thick. The joints will be 3/4" wide.
Should I lay the mortar bed, set the bricks down first, wait a few days for the bed to cure, then fill in the joints, or should I fill in the joints at the same time?
Old 07-15-20, 03:11 AM
Marq1's Avatar
Received 1,099 Upvotes on 999 Posts
You would set the bricks then fill with sanded grout!
Old 07-15-20, 04:43 AM
P
Received 1,759 Upvotes on 1,572 Posts
Do all the mortaring at the same time as you set the bricks. I normally lay down several feet of mortar on the bottom. Then I butter the end of the brick and place it. Your mortar joints are large so it will be difficult to keep the bricks from moving but a stiffer mix should help.
Old 07-15-20, 09:14 AM
Ok thanks I will do both at the same time.
Old 07-15-20, 10:26 AM
P
If you are inexperienced doing masonry wear gloves. Many people find it irresistible and can't keep their hands off the mortar which is quite hard on your skin.
If this brick work will be visible work very carefully to not let the mortar touch the visible face of the brick. Even if you think you wiped or brushed it off it will leave a gray/white grout stain. It can be cleaned off later with a strong acid but it's easier not to mess it up in the first place.
