Repairing a broken retaining wall made of concrete cylinders
I’ll try to explain this briefly:
Old house in North Toronto. The City eliminated the ‘laneway' behind the houses and gave the to the property owners on either side. The owners of my home at the time, chose to build an extension to the garage.
From what I can tell, they supported the extra few feet of the garage as well as a new retaining wall/wall to the right of the garage with stacked concrete cylinders. This was 40y ago?
The 1-2 ft ‘retaining wall’ (made of cylinders) beside the garage has since given way. The 2-2.5 ft wall that stood on it, made of concrete block/poured concrete, supported by the metal poles has fallen.
I’ve removed about 20 cinderblocks and patio stones that had been piled there as a makeshift solution.
What’s left is the concrete cylinders, and the metal bars that were the part of the former wall.
I’m looking for advice around how to address this.
I’m not terribly concerned about this area eroding and am prepared to do repairs from time to time if necessary. A permanent solution would be best.
Open to any recommendations.
Pictures are walking along the side of the garage approaching the wall, then from the opposite side, facing the wall/back of garage.
Those look like sample cores taken when inspecting a concrete pour. Often done for freeways and if you have a good eye you can sometimes spot the telltale circle in the road when driving.
I would look into engineered precast concrete retaining wall blocks. The good type are rarely sold at big box home centers and need to come from a more industrial concrete supplier. If you go to the manufacturers website you can find installation instructions.
That would make sense as I hear the old owners worked for a major construction company thats contracted for a lot of roads in Toronto. The cylinders only support the 4' extension on the garage. The remainder of the foundation is likely more traditional.
If you look at the 4th pic, you can see:
the right side of the pic is the back of the garage. The cylinders are still in place behind the chain link. There's blocks on top of the cylinders, and everythings' solid.
the left side of the pic is the small space beside the garage where the cylinders have been pushed ~4-8" outwards. It's just these few cylinders I'm going to move.
My thought is to dig them out, & replace them in line with the wall.
But then how do i prevent them from simply shifting again?
That is why I recommended a engineered retaining wall product. While the cores are strong there is nothing to prevent them from being pushed by the soil pressure on the back side.
Wanted to get something done regarding both the retaining wall and the downspout redirection before the frost, so here it is.
The plan: to reduce the chance of freezing, i was able to get about a 1/2" per foot slope. I did lay a bed of gravel to ensure the corrugated pipe didn't have any low points. Some of the corrugated pipe is exposed (right next to the house, in the area that gets sun.
What's interesting: In order to achieve this slope, I had to feed the corrugated pipe through the retaining wall (simply by leaving out one concrete core)
Also Interesting: There's (at least) 2 more rows of concrete cores buried. You can see one at my feet in this pic, then there's another below that.
Here's a pic with digging about 90% done and before gravel
50% gravel in place, levelling
And finished:
The pieces of wood are there in case the cores do shift, the lowest level can only move about half an inch.
I think this should do the job, but first test is this winter.
Thank you for posting back with your solution. When you first asked your questions I never made the connection that you were the same person in the two threads.
The area leading to my garage is large concrete slabs, probably ~50y old, not the greatest shape, with many cuts (from when an addition was built) and cracks, but it's not in the budget to remove/replace any time soon.
[b]I'm trying to understand what product(s) I'll need to address:[/b]
1. gaps between concrete slabs and between the asphalt which makes up the driveway and the concrete slabs (ranging from 1/4" to 3/4")
2. cracks in the concrete slabs (mostly ~1/4")
3. the big gap between the concrete blocks and the garage apron. about 1-2" down is soil. I expect to use some sort of backing on the soil then ____(?)
As you can see the concrete is in very poor shape overall. I believe this is due to 50 years of Canadian winters, general neglect and, abuse of ice-melting salt.
Any advice is appreciated.
A gap of approx. 3/8" has appeared between our asphalt driveway and garage. I'm looking for a product to fill the gap. Several products (primarily caulks) seem to do the job, but none actually say so. I assume there must be products commonly used because most asphalt driveways abut masonry at some point. Any suggestions?
