Masonry Wall Corrosion
Old 10-10-20, 01:57 PM
O
There appears to be a triangle-shaped pattern of corrosion coming out of the ground. I've also attached my neighbor's backyard and you can see the sprinklers are adjacent to the wall we share but his side, for some reason, is spotless.
Can you tell what's causing the Corrosion?
* Edit: Here are the photos of the front and back of the wall:
Neighbor's side of the masonry.
Our side of the masonry.
Old 10-10-20, 02:36 PM
Marq1's Avatar
Received 532 Votes on 492 Posts
Not seeing anything of issue, need more detail!
Old 10-10-20, 03:03 PM
XSleeper's Avatar
Received 988 Votes on 899 Posts
It no doubt has to do with vapor drive when the sun hits the wet CMU wall.
