brick walk
Old 11-15-20, 02:58 AM
C
Question brick walk
brick walk I have many bricks left over from a job with 8 holes in them could these be used to make a walk way ?
Old 11-15-20, 03:02 AM
Received 426 Votes on 381 Posts
Welcome to the forums Carl
Anything's possible, if you lay them flat - weeds can grow out the holes, If you lay them on edge it will take some effort to make them stable
Old 11-15-20, 05:43 AM
A
Received 72 Votes on 65 Posts
Welcome. If you are in an area subject to freezing temperature, moisture in those holes will freeze and crack them. Maybe not all of them, but enough to diminish your project sooner than you'd like. Also, I don't know the differences, not a brickologist, but there are definite differences between that type of brick and pavers, and based on what I have seen, with or without the freezing consideration they do not hold up nearly as well as pavers in direct contact with soil.
