Caulk for Basement Exterior
Hello Helpers,
I live in Central Ohio, and I have a vertical hair-line crack on the exterior of my concrete basement. It is about 1/8 inch, and I have been looking to buy the GE Silicone II Caulk for Concrete/Mortar but it's unavailable in all the big stores around me, like Lowes, Home Depot, Ace Hardware. The concrete product is listed here -- https://www.lowes.com/pd/GE-Silicone...ulk/1000619021
I wonder if any other typical GE Advance Silicone II would work? As long as it is Weather-Proof and Flexible? The weather here would range from 0F ~ 100 F.
Thanks
Sean
Thanks
Sean
Hello xSleeper, Thanks for your suggestion.
I just discovered that the vertical hairline crack has already expanded into about 1/4 inch wide. I tried putting on Quikrete Concrete Sealant 4 years ago, and after 2 years the hardened seal just cracked and I left it open for 2 years. https://www.homedepot.com/p/Quikrete...2010/100318474
I notice that during winter time the crack would be widened, and in summer it would diminish. I figure now would be a good time to put in some seal when the days warm up to 50s.
Do you think this slow widening of crack warrant a different solution? I did call a basement foundation expert over 4 years ago and he said it was not an issue, as he measured the basement wall cave-in.
Thanks again
Thanks again
