Best polymeric sand for pavers
Old 05-09-21, 09:55 AM
Received 2 Votes on 2 Posts
Hi all,
Had a beautiful patio and walkway installed about three years ago. Pavers were Cambridge, polymeric sand was Alliance/Gator. Unfortunately the polymeric sand never set well in the bigger joints, always seemed rubbery, and has now washed away quite a bit from those locations. This was after an initial washout within a couple of weeks and the contractor re-applying the sand.
I went to the supplier of the products who had indicated Alliance improved the Gator products within the last year or so. Not sure I want to go back to them considering the issues I've seen. Planning to just pressure wash and "touch up" the bigger joints rather than re-do the whole patio since the rest of the sand is in good shape.
Can you recommend a suitable, solid polymeric sand so I can re-do these joints? Thanks.
Also - I have one capstone that has loosened and will probably pull up. Can you please also recommend best block adhesive to reinstall it?
Thanks!
Old 05-09-21, 10:58 AM
Marq1's Avatar
Received 950 Votes on 862 Posts
Have pretty much always used Gator sand, honestly it's a pretty basic product sand and binding agent, the application/installation is more critical than the product.
Any name brand block adhesive will work, just dont use a construction adhesive!
Old 05-09-21, 11:54 AM
P
Received 1,564 Votes on 1,406 Posts
Polymeric is not good for big gaps. But, I've found it holds up pretty well if installed properly. I've used a couple different brands of Polymeric and they have all performed about the same. The installation/application is VERY important. The binders and sand particles can separate apart during installation which can create very weak areas. Also, using a vibratory plate compactor really helps a lot to get the sand to densely settle down into the joints before watering.
