Chimney cracks - call a pro or DIY?
Old 06-15-21, 09:53 AM
D
New home - contractor friend didn’t think it was much of an immediate worry but it makes me nervous.
Do these require immediate professional attention or is this less scary than in my brain and can be worked on by an amateur?
Old 06-15-21, 09:56 AM
Received 3,420 Upvotes on 3,066 Posts
It's not an immediate concern to the point where it fall down tomorrow.
Can you post a picture of the entire chimney from further back ?
Dbl_dbl voted this post useful.
D
One more pic. Don’t like going around my friends advice but he isn’t a mason.
Old 06-15-21, 10:00 AM
D
@pjmax thanks for the reply. Here are a couple shots from further away.
Old 06-15-21, 11:48 AM
P
Received 1,766 Upvotes on 1,579 Posts
Yes, it is best that the cracks be repaired. Open cracks will allow water to get in and freeze, furthering the damage. But, it's not critically important that it be done immediately. The chimney appears to be in pretty good/sound condition but the cracks won't heal themselves and will only get worse with time.
Old 06-15-21, 11:55 AM
C
Received 282 Upvotes on 232 Posts
Not a mason either, but I have repaired similar mortar cracks on my chimney. However, I don't know about the cracked bricks.
Old 06-15-21, 12:18 PM
D
Thanks everyone. @Pilot Dane - is repairing the cracks something an amateur should attempt or will it require a pro?
Im comfortable with many home projects but this kind of structural issue is a bit more intimidating.
Old 06-15-21, 12:52 PM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
No harm in trying. You going get mortar and a brick pointing tool. The best thing to do is to remove the existing mortar then replace it.
The cracking brick concerns me. How old is the house or at least the chimney? If it's been like that for the life of the house then no major concern. But if those cracked bricks are fairly recent then a settling issue may be at hand. You might want to have the tiles inside the chimney checked.
Old 06-15-21, 01:11 PM
D
@Norm - the house is approx 30 years old. We haven’t been here long but the cracks caught my eye today - hard to remember if they were that prominent before but they look larger. I’m prone to overthinking these things, though.
I haven’t seen other signs of settling issues - no cracks elsewhere, door issues, leaks etc, however I’ve read the chimney could have its own settling issues if it’s on it’s own foundation.
The idea of it being a house foundation issue has got me sweatin now!
Old 06-15-21, 02:02 PM
P
Yes, repairing the cracks is very much a DIY project if you have the ladder or scaffolding to safely work at height. There are many websites and videos that can show you how it's done. You use a angle grinder to clean the old mortar out of the cracked areas. Mix up your mortar. Spray some water into the crack areas you cleaned out. Then tuck/pack or squirt mortar into the joint and finish the surface.
Since these repairs will be visible I would get some mortar mix and make a small batch and give it the same surface finish as your chimney's joints and let it harden. Then you can see it's color to determine if a easy to use bagged mix looks good enough or if you want to get into mixing your own recipe to get a closer color match.
Old 06-15-21, 04:55 PM
Norm201's Avatar
Don't loose sleep over it. It's not uncommon and will hold up for quite some time. It's just that the sooner you fix it the better.
I also need to do similar on my daughter house.
