Bunkie Pad
Old 06-23-21, 10:23 AM
B
Bunkie Pad
Hey folks looking for a little advice. I've had a custom bunkie made that is 9'x12' that is set to arrive in a couple of weeks.
as you can tell from the pic, we are looking for a cheap fix to support the middle of the Bunkie. Stone, concrete, cinder?
Thanks all
Old 06-23-21, 10:39 AM
P
Received 1,759 Upvotes on 1,572 Posts
.... what's a bunkie?
If you are talking about a storage building are you sure the middle needs any support? Does your building come with a floor or do you have to provide that?
Old 06-23-21, 10:50 AM
Received 3,415 Upvotes on 3,063 Posts
A bunkie is like a small house..... a bunk house. They are fairly expensive.
You should check with the supplier of the bunkie and see what is required.
I'd imagine the bottom needs to be fairly substantial.
B
Bunkie= small cabin for sleeping. I'll need middle support for sure
Old 06-23-21, 11:18 AM
A
Received 80 Upvotes on 70 Posts
would contact the manufacturer and see what the floor joist is and spacing to see if you need more support or not if you do really no way to access it once installed so would probably just do concrete and blocks.
Old 06-23-21, 11:45 AM
B
Thanks Alan, great advice! How would I go about doing the concrete and blocks from this point?
Old 06-23-21, 01:30 PM
P
Why do you think it needs support in the middle? Did the building's manufacturer spec or require it? 9' wide is pretty narrow and I would be surprised if your building needs support except for the perimeter.
Old 06-24-21, 05:03 AM
B
Hey Pilot Dane,
I wasn't certain as I am a novice DIYer. I suppose if the joists are where they should there should be no problems.The manufacturer claimed he couldn't rest the bunkie on the foundation I made. I thought that's what he did for a living!
I suggested something like this with a few metal poles to slide it on?
Old 06-24-21, 08:41 AM
P
"The manufacturer claimed he couldn't rest the bunkie on the foundation I made."
That's a footer and foundation wall fitting for a house. I am really curious why he can't use it. Is it that it doesn't provide support where the building will need? Or does he not know how to set the building on top of it?
Old 06-25-21, 06:12 AM
B
Pilot Dane,
I dont think he knows wtf he is doing! These guys just want the sale, drop it and go. I guess he's going to have to figure it out.
Old 06-25-21, 07:35 AM
P
My guess is they have a off road forklift device. In my area they are used when delivering storage sheds. It relies on them being able to drive where they want where they then set the building down on "blocks". Your continuous foundation wall might prevent them from driving in like they are accustomed. Your idea with the metal post as a roller could work though you will need more rollers.
