Polymeric sand substitute?
Background: I have a large paver patio that is about 18 years old. A few areas have settled a bit and I'm in the process of removing and resetting pavers in those areas. I'm going to be cleaning out all existing joints using a water hose on sharp stream. A couple test areas shows this working reasonably well, down about an inch or more. These are pretty narrow joints, 1/16" to 1/8" in most areas. 2-1/4" thick Borgert pavers.
The question: The polymeric sand (Techniseal EZ Sand from HD) is getting really expensive, probably well over $100 even with the narrow joints. I'm wondering if it would work sweeping in a 4:1 sand/portland mix, and then watering it in like a polymeric sand. Sand is under $3 a bag (50#) and I would need 4 to 5. Portland is $14 a bag (96#) and I would need just one. Assuming the sand is fine enough to sweep in (haven't tried that yet), any ideas if this would work? Any "gotcha's" you can think of?
Edit: I can't find any MSDS sheets that would suggest what's in EZ Sand. But as hard as it is after curing, I suspect is has to have some portland in it. The instructions also talk about curing times
Buy the polymeric or use standard sand. Considering the cost of paver patio a hundred bucks in minimal. It's like complaining about the cost of light bulbs when you live in a million dollar house.
Do not use cement & sand (almost mortar) as it is very brittle and will soon crack. Polymeric is sand with a latex binder so it remains flexible to accommodate the slight movement between the paver blocks.
About 10 year ago I built a flagstone patio. I used broomed in sand for the joints. Within a couple of years I was fighting washout, weeds and anthills. Two years ago I redid the joints with polymeric sand. A bit pricey but it solved my problems.
Some polymeric sand has a Portland component but the key is the polymer. You can find lots of MSDS sheets on line and the polymer mix is usually listed as proprietary.
OK, you talked me down, polymeric it is! When I originally did this patio area, I just used plain sand in the joints. It lasted about 10 - 12 years before I had to start dealing with plant growth, probably because of the very thin joints, so not too bad. But at 72 years old, I don't want any more extra maintenance than I have to. Thanks for the input!
