Replace vinyl with brick
Old 11-24-21, 01:00 PM
Z
Can vinyl siding be replaced by traditional brick on a house?
Old 11-24-21, 01:07 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Brick needs to sit on a concrete footing.
joecaption voted this post useful.
Old 11-24-21, 03:07 PM
Received 128 Upvotes on 113 Posts
That would be one hugely expensive project.
If you can make it to a real siding supply company, there is a few company's that make cement based panels that look like real brick.
You chose not to include a location in your profile so no one will have a clue where to suggest looking, you could be anyplace on the planet.
I saw it long ago at Lancing Building Products.
Old 11-25-21, 06:16 AM
P
Received 2,116 Upvotes on 1,895 Posts
Switching to brick is expensive and causes a lot of issues. The earth around the house needs to be excavated to either extend the house's existing footers to support the brick or install a brick ledge onto the existing foundation walls. Then you have a big problem with every door and window as the brick and the requires air space between the brick and house adds about 4 1/2" to the thickness of the wall. All the windows and doors are now recessed in brick pockets that need to be re-trimmed & flashed. Then you need to look carefully at any porches or decks as they can be complicated to brick around properly.
Old 11-25-21, 09:07 AM
Old 11-25-21, 09:25 AM
Tolyn Ironhand's Avatar
Received 867 Upvotes on 730 Posts
Adding brick veneer or an overlay product like Nova Brick would likely be the easier, less expensive option.
Old 11-25-21, 11:27 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
If your going the route of thin veneers, there are tons of choices and IMO many look better than brick!
Here is an example of what I installed on my small shed a couple years ago!
