Garage Door Threshold Seal
Old 02-27-22, 12:10 PM
L
Received 1 Upvote on 1 Post
I want to install a 20' section of the garage seal on concrete and tested a 4' section applying Extreme Heavy Duty Liquid Nail adhesive to clean and dry surface then let set 24 hours in temperature above 55 degrees but it did not hold.
Comments/Suggestions on the type of sealant to apply to secure the door seat to concrete.
Old 02-27-22, 02:07 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Try a PL product, Liquid Nails is OK for wood but not much else>
Old 02-27-22, 02:43 PM
L
Search and found local ACE hardware carries the product, intend review item description and if w/in my application purchasing in next couple of days,
Thank U much for the suggestion!!
Old 02-27-22, 03:00 PM
XSleeper's Avatar
Received 1,924 Upvotes on 1,728 Posts
We know you have concrete on one side, but we know nothing about what you are trying to glue down. Is it aluminum? Plastic? Rubber?
Old 02-27-22, 03:14 PM
L
It is a 20' heavy duty rubber garage door seal I am attempting to secure to concrete in an effort to minimize water from from entering the inside garage.
Old 02-27-22, 03:31 PM
XSleeper's Avatar
Here is the sealant recommended for use with that product.
https://www.amazon.com/Everbuild-STI...s%2C939&sr=1-3
and this product would be similar:
https://www.amazon.com/SikaBond-Ulti...s%2C939&sr=1-6
IMO your bigger problem now is you have both sides of everything mucked up with the wrong sealant.
Old 02-27-22, 03:49 PM
L
The 1st link: Everbuild STIXGY Stixall Ultimate Power Cartridge 300 ml suggest the product can be used for the same/similar threshold I am attempting to install.
Xsleeper and all I appreciated the comments and suggestions!!
