Retaining Wall in Sand
Old 07-10-22, 03:02 PM
Hello All. I am planning on building a 3-4' high x 20' long retaining wall by next year. Live in a coastal area and my yard is basically sand.
Been researching a ton. I cannot find a definitive answer. Do I need to utilize 3/4 stone for the base/footing material? Or could I just use the sand that's there?
Old 07-10-22, 11:21 PM
Marq1's Avatar
Received 1,145 Upvotes on 1,038 Posts
You will absolutely have to remove sand and replace with some type of compactable material. Sand is not a stable material to build on,
Old 07-11-22, 04:54 AM
P
Received 1,853 Upvotes on 1,659 Posts
I agree. You definetely need a compacted stone base.
Old 10-20-22, 07:09 PM
C
Per section R403.1 some kind of foundation is required. Given the unstable nature to sand I would suggest having the retaining wall properly engineered by a licensed professional. Retaining wall design requirements are in code Section R404.4.
[Removed by admin]
