Paver Question
Old 08-21-22, 06:37 PM
T
Paver Question
I want to install some pavers right outside my back door. There's some concrete from the house foundation that looks like a spillover. Do I remove this so I can push the pavers flush to the house? And if so, what's the best way to break this off? Thanks
Old 08-21-22, 09:43 PM
Marq1's Avatar
Received 1,141 Upvotes on 1,034 Posts
If the material is in the same location as where the pavers will sit then yes it needs to be removed. How to removed is dependent on how much and how thick the slag is.
If thin it can simply be chipped away, if thicker it may need some cutting/grinding to remove. You don't want to beat on it so much that you risk breaking away chunks of the foundation.
Old 08-22-22, 11:12 AM
T
Thanks. Maybe I'll try drilling some holes in it to make it easier to remove without breaking the foundation.
