Garage 'Crete pour
Old 08-22-22, 09:04 AM
B
Garage 'Crete pour
Good afternoon,
Just prepping to pour a garage floor this week.
Just wondering what I should use for lag bolts for the 2x6's. Pic attached
EDIT please note this pic is only an example. Not the actual job.
Thank you friends!
Old 08-22-22, 09:38 AM
Received 753 Upvotes on 658 Posts
Not sure what you intend to use lag bolts for ??
If you mean to hold the form board in place I usually cut up rebar and pound it in next to the form board.
Old 08-22-22, 09:48 AM
P
Received 1,840 Upvotes on 1,647 Posts
I too don't know what lag bolts would be used for. Forms are generally attached with deck screws or double headed nails where possible. Wood or rebar stakes driven into the ground to provide support on long sections so the form boards don't bend. And, you can even pile stone or dirt or place heavy objects behind the boards to hold them in place.
Old 08-22-22, 05:37 PM
B
Thank you gentlemen. Cheers
