I've read many posts and viewed many vids, but still unsure of the best method to repair these hairline cracks. It's basically one crack in the center of the wall that goes up the wall about half way toward the roof line. Supported by a thick metal girder. South facing so it gets full sun in the afternoon and rain does impact it. Will experience -20 temps in the Minnesota Winter. Just above the garage door.
Home was built in 2005 by DR Horton. Seems to be the rather usual light gray colored mortar. It's not a structural wall, except for holding the 20 or so courses of brick above it. Type N mortar? Or something more flexible? Is mortar in a tube a viable option? Mortar color is a major concern as the area is quite visible - I will say it looks like standard Quikrete mix. I'd rather not have to grind out the mortar, but if that's the only proper method I'd entertain it.
The real fix is called tuckpointing where the mortar is dug out and replaced, They do have caulk materials but that is kind of a band aid as it doesn't fix the problem. Cracks like that probably coming from some settling.
Concur with Marqs' response.
Mortar isn't flexible, but there are some mortar repair products that flex. Sika makes a mortar repair that looks close to color you have.
A challenge with tuckpointing is matching colors. We can give you some tips on matching mortar if you go that route.
Is the ground under this area sinking/settling? You may want to shim or add support to prevent situation from getting worse.
Hi all. I am grading the side of our house, and I am going to install a French drain.
I was wondering if I need to consider any specific type of fill to use to build up the slope against the side of the house.
The base is clay so I am going to be using that, but I may need to add to it to get 2” of slope over a 6ft run.
There already is a sort of grit in the existing paint on the outside basement vertical wall surface. The paint job is quite old and some sections have this grit and some do not. For consistency I am hoping to repaint using paint with similar grit. What do you call this .... grit...? If I have the name I could search and purchase it.
thank you!
Dave
