Driveway Sealer
Old 10-10-22, 07:38 PM
B
Received 4 Upvotes on 3 Posts
Driveway Sealer
I've been applying coats of asphalt sealer to my driveway which badly needed it. Sealed large cracks beforehand.
My question is: how many coats can or should I do? Im kinda getting obsessed to filling in every imperfection but don't know if that's realistic or the right thing to do.
Attaching pictures to see what it currently lo0ks like.
Old 10-10-22, 10:59 PM
Marq1's Avatar
Received 1,145 Upvotes on 1,038 Posts
Sealers wears off with time/use, from the pictures that looks to be in pretty good shape. It will never be perfectly smooth, I used to apply about every 1 1/2 years.
Better quality sealers are worth the extra cost, they contain more fillers, next time pick up the cans, you can feel how much heavier the better material weighs.
Old 10-11-22, 03:51 AM
Received 759 Upvotes on 664 Posts
One coat should be sufficient. Those in the business of applying asphalt sealant claim it should be done every yr but IMO 2-3 yrs makes more sense. While the black will fade during the first yr, normally the sealer is still good enough to continue to protect the asphalt.
Old 10-11-22, 05:32 AM
B
Awesome. Ok thanks so much. Ps I did get the highest quality available - blackjack 1000. Heavy buckets for sure!
Old 10-11-22, 05:58 AM
Received 1,198 Upvotes on 1,153 Posts
Sealer doesn't fill the voids you have so trying is only going to waste time and money. I think you're good to go already.
