GraniteGrip or Decorative Concrete Stain or Porch or Patio Floor Paint
Old 02-16-23, 09:32 PM
R
Hello Everyone,
our driveway and the sidewalk that comes into the main entrance are made o concrete and are very old.
I came across Beher Granite Grip and thought it will be a good idea to use that. I pressure-washed an area of concrete, etched it with muriatic acid, and washed and applied Granit Grip on the surface. It looked great after two coatings.
After a few weeks when I went to Home Depot to get 5 gallons, I saw that the containers of Granit Grip was very few and that was the case in all Home Depots.
I am wondering if this product is being discontinued by Home Depot.
MY QUESTION: Would you recommend using Granite Grip or use Decorative Concrete Stain or Porch and Patio Floor paint or Porch and Patio Anti-slip Floor paint
#Driveway #Floorpaint
Old 02-16-23, 11:35 PM
Marq1's Avatar
Received 1,142 Upvotes on 1,035 Posts
Personally I wouldn't use anything with the name Behr on the can, cheap products, lots of issues, lots of complaints. HD sells paints based on cost, not quality.
Old 02-17-23, 05:58 AM
C
Received 288 Upvotes on 238 Posts
None of the local HD's have the 5 gal in stock. However, the closest store to me has plenty of the 1 gal for around $65. I don't know anything about the product although I read one review that said the product started peeling after 2 years, but the reviewer admitted that they did not properly prepare the surface.
Old 02-17-23, 06:06 AM
Received 759 Upvotes on 664 Posts
Stain does ok on exterior concrete but I'd shy away from paint - sooner or later it will peel.
Old 02-17-23, 01:36 PM
N
Received 5 Upvotes on 5 Posts
I am planning to do something like that. This is what i am thinking. I am using Rapidset Mortar Mix. Mix it to a pancake batter consistency and then pour it and let it level out on the concrete. Maybe 2 coats. After that, apply a masonry paint. Behr masonry paint has a 20 year warranty. I applied it to a retaining wall i built last year. It's holding up good.
Old 02-17-23, 02:14 PM
N
Well i just realized that there's a hack to make a surface non slip. 4 part paint and 1 part sand. Has anyone tried this hack?
Old 02-18-23, 03:29 AM
I've never mixed in masonry sand but I have used the sand [non slip] additive they sell at the paint store. It works well but it tends to wear off in the higher traffic areas.
Old 02-20-23, 05:50 PM
N
"I've never mixed in masonry sand..."
It's not masonry sand. It's rather play sand from the orange store. Masonry sand is too fine.
