Gap between brick wall and roof fascia/soffit/gutter
Old 10-16-23, 05:37 PM
I
Received 2 Upvotes on 1 Post
Hello all!
We live in a semi-detached home.
Between the two 'addresses' between the outside wall and the base of the roof, there is a portion of brickwork of about 10 rows that 'juts out of the wall'
It seems that there is a gap between the top row of the brickwork and the metal part of the roof that separates both sides of the building.
I need to close this hole, since water can enter and birds are building nests in there.
By looking at the images linked below, would you happen to know if I need to add additional bricks or if there is another way to close the gap?
It's a long way up to the top of the house (3 stories); it's in a place where setting up scaffolding is not the easiest, and I'm a little hesitant to be working on a ladder, so i might just call a professional, but I am wondering if you could point me in the right direction?
thank you!
https://flic.kr/p/2p9HTe1
https://flic.kr/p/2p9DW5f
https://flic.kr/p/2p9DYDJ
Old 10-16-23, 05:43 PM
XSleeper's Avatar
Received 1,924 Upvotes on 1,728 Posts
Yeah, looks like a brick is missing. You might also be able to close it up with a little metal flashing and zip screws or pop rivets.
Ialsomakesoap voted this post useful.
Old 10-16-23, 06:31 PM
I
thank you! i'll try that!
Old 10-17-23, 05:48 AM
B
Received 304 Upvotes on 269 Posts
Nor sure what "metal part of roof" you are referring to because I see gutter spikes on the gutters that normally are driven into wood. If the framing for the brick bump out is wood, there may be a structural problem causing bricks to loosen. I would call a professional.
Old 10-17-23, 06:13 AM
XSleeper's Avatar
The parapet cap on top of the brick is metal.
Old 10-22-23, 07:37 PM
I
thank you XSleeper and beelzebob for your inputs (and sorry for the delay in responding)! another thing I appreciate is the new (and proper) terminology to be used (i.e. "parapet cap" and "brick bump out"). i will definitely consider getting a professional should things start to look/get too complex.
