Making a 6 inch hole in brick
Old 05-19-24, 04:59 PM
Received 2 Upvotes on 2 Posts
I needs a 6 inch+ hole for exhaust ductwork. This is double brick construction. I drilled a pilot hole from the inside and some of the face fell off the brick. That is fine as I'm removing that whole part but I want to avoid it on the rest of the job.
I was thinking to score the outside of my hole with a grinder. To remove whole bricks (which there will only be one) I was thinking to drill through the mortar around it in a few places (hammer drill with masonry bit). Any suggestions?
I was hoping to a void the soldier row but I don't think I can (due to a joist on the inside).
I believe we are talking 6 inches thick of brick.
Old 05-19-24, 05:02 PM
I don't see my pic...but when I hit edit it is there....confused....
Old 05-19-24, 05:03 PM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
Check ebay for a 6 1/4 or 6 3/8" diamond hole saw.
Photos are not working. You can paste a link if you have them stored in the cloud.
Old 05-19-24, 05:08 PM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
If you don't want to buy a core drill you can take a hammer drill and drill a series of holes around the perimeter of the hole you want to make. Then you can break out the bricks you want to remove. It will not make a nice hole but it will get the job done.
Old 05-19-24, 05:16 PM
XSleeper's Avatar
Sadly, banging on bricks usually doesn't turn out well, since the small perimeter pieces will break loose and fall out, making a much bigger hole than you want.
Old 05-19-24, 06:12 PM
C
Received 176 Upvotes on 144 Posts
You may be able to rent a 6" diamond core bit and a suitable motor to drive it. You'd only need it for an hour or so.
