Gaps in brick stairs
Old 05-24-24, 02:19 PM
R
Hello all.
I have brick steps with what I think are called limestone treads. As you can see, there are gaps that have formed between the bricks. Can someone advise me on how to fill in this cracks as a temporary measure? I will work on the permanent fix later.
There are also gaps between the tread and the back riser which is made of brick; as you can see in the second pic.
Ty!
Old 05-24-24, 02:45 PM
P
Received 2,271 Upvotes on 2,023 Posts
The stairs are in very poor condition. Some of the "gaps" you mentioned are giant cracks.
Personally, I would not bother with a repair. It won't do much to extend it's life and cosmetically any fresh mortar is going to really stand out as different.
But, if you want to do something you can re-point the joints where the mortar is deeply recessed and fill in the gaps you mentioned. Easiest would be to get a bag of mortar mix that has the sand included so all you have to do is add water. Type N would work.
remodel566 voted this post useful.
Old 05-25-24, 11:23 PM
R
Ty
Old 05-25-24, 11:25 PM
R
@Pilot Dane Ty very much for your reply. I was wondering, what do you think about me using this product instead?
https://www.lowes.com/pd/Sika-10-1-o...lant/999977060
I am not doubting your expertise. I am just wondering if this would also do the same job. Ty
Old 05-26-24, 03:59 AM
P
I would not use any caulk.
