Pressure washer surface cleaner safe for travertine
Old 06-11-24, 05:21 PM
Received 1 Upvote on 1 Post
I have an 18-year-old scabos travertine patio. Itís in good shape, but it could use a cleaning. Is it OK to use a 2000 psi electric power washer with a circular cleaner? Would that be strong enough to remove light weeds and moss within the joints? I would then lay fresh polymeric sand over the top
of
Old 06-11-24, 05:47 PM
Received 4,139 Upvotes on 3,717 Posts
That will do it and it will blow the sand out of the joints.
Old 06-11-24, 06:13 PM
Ahh why do I see tons of ppl using wand when this appears much quicker ? I feel silly for not knowing this
Old 06-12-24, 05:06 AM
P
Received 2,309 Upvotes on 2,054 Posts
A wand gives you more control. It allows you to focus on areas that need more cleaning and to avoid the gaps between the stones if desired to minimize blowing the sand away. Plus, not everyone has a floor cleaner attachment.
I don't think you will get great results if your pressure washer is 120v powered. It simply doesn't have the power and water flow to do serious cleaning. You may want to follow up and hit difficult areas with a hand wand.
Old 06-12-24, 02:02 PM
I was envisioning a spinning nozzle........ rotating nozzle.
It's a 0į spinning tip.
