concrete overpous
Old 09-06-01, 06:51 PM
Guest
I have an addition on my house that is approx 1 1/2 inches lower than the main slab. The walls have proper footings. I want to cap the slab to match the main slab. The one contrator I had quote it seemed unsure but was going to fasten stucco wire down them use 75 percent acrylic and 25 percent portland. He wasnt going to remove the carpet adhesive remaining from the old carpet. This worried me. He was also worried about the new cement cracking during drying. Any suggestions?
Old 09-07-01, 09:10 PM
some help
Hello
They have a product they use for fire and sound proof second floor units every where, it is light weight and will do you a great job...differant area call it differantly here it is gypcrete check around if you can not find it where you are get back to me I will help you find it....Good Luck
