Blinding concrete entryway
Old 09-07-01, 05:29 AM
boomlaka
Cool
We had a new concrete entryway and porch area poured. The concrete is very light and bright, when the sun is directly on it (which is most of the day) it is blinding. Is there a product that can be applied to darken it. Needs to be non-slick and permanent.
Old 09-07-01, 09:03 PM
some help
Hello
There are many good concrete stains out there you need to follow the direction to the tee that come with each stain you use, but you can also acid wash the area let dry and use liquid lamp black used to color concrete at the concrete plant, thin it down with water a little goes a long way here, roll on with a paint roller or squeegee.... and wash off....and let dry.....you should test in an area out of site if possible to get what you want....Good Luck
Old 09-08-01, 06:04 AM
boomlaka
Thanks for all your answers. I've created a file for all my projects and will definitely follow your advice. Thanks again.
