Masonry
Old 09-18-01, 08:53 AM
Guest
How do you install or tips for installing cultured or man-made stone?
Old 09-18-01, 07:31 PM
2
http://www.culturedstone.com/ tech info (pdfs)
This type? or something else?
Old 09-28-01, 06:58 PM
some help
Hello
is this a counter top in a bathroom? if so fit the top, install all the plumbling check the fit and use a good shower/tub coulking around the edge on the cabinet and set in place do not finish the pluming until calking is dry and top is tight, if it has a loose back splash you do it the same way.....
Good Luck
