Holding screws in brick/mortar
Old 11-29-01, 01:05 PM
cbarry
Hello,
Please pardon a potentially stupid question.
I am installing a new doorbell into the brick on the outside of our house. The kit called for 1/16" masonry bit. Well, after searching high and low, the smallest I could find was 1/8". So I drilled the holes, and now, of course, the screws are not tight in the holes.
Can someone recommend a solution? I have thought about putting a caulking or some sort of glue around the screw, but I would like some advice.
Thanks a lot in advance,
cbarry
cmbarry@bellsouth.net
Old 11-29-01, 01:33 PM
Mike Swearingen's Avatar
Received 1 Vote on 1 Post
Cool
Use small plastic or lead anchors tapped into the drilled holes, and screw the doorbell screws into them. Anchors are normally used in mortar and brick.
Good Luck!
Mike
