Hanging pictures/sconces in brick/cement
Old 12-19-01, 07:47 AM
jwhite2001
Question Hanging pictures/sconces in brick/cement
The wall where our fireplace insert is located is completely brick. I would like to hang some sconces for decoration. What do I use and how do I need to hang them? Do I drill holes in the cement and use certain hardware or what? Help!!!!!!!
Old 12-19-01, 01:22 PM
Mike Swearingen's Avatar
Received 1 Vote on 1 Post
Cool
Drill holes only in the mortar between the bricks with a masonry bit (FAR easier than drilling brick).
Get expandable lead anchors to fit into the holes, and tap them in with a hammer. (The anchors come in different sizes, based on the load.)
Get wood-screw-thread bolts or screws, and screw these into the lead anchors, leaving the heads (with washers) sticking out enough to hang your picture wire.
Tighten the screws or bolts down to hold the sconces.
Good Luck!
Mike
Old 12-20-01, 03:55 AM
jwhite2001
Response to Hanging sconces in brick/cement
Thanks so much for you quick response! I will try your suggestion. On to the hardware store!!!!! Thanks again.
