Cosmetic patch work
Old 05-22-02, 04:20 AM
rskinner
Cosmetic patch work
I have a concrete slab that is 3 years old and when they poured it one of the forms on the end had a belly so the end of the slab looks slightly rounded. In order to make it square, I would have to add 2-1/2" to one corner and taper it down to nil about 3 feet from the corner. This is totally cosmetic and will have zero weight on it. I have enough room for most of it to drill and install some 3/8 rod to help hold it.
What is the best mix for hand trialing this, and do you have any other recomendations ie, primer or bonding agent?
Old 05-22-02, 05:12 AM
pmg
Clean the existing pad well where new concrete will come in contact-scrub with a stiff wire brush and hose off.As you said,drill some holes and hammer in some lengths of rebar sticking out a bit.Acryl 60 is a great bonder,as well as Thorobond.You can even slide some wire lath in your new pour.Your other option is to square off the belly by sawing it off with a cut off saw/diamond blade combo if the edge won't be seen.
